how to efficiently concatenate 2D arrays
I need to concatenate two 2D arrays efficiently. (E.g. this will be on an embedded system in a fast-ish loop.) Each array is 20 rows by 20 columns. The rows are channels and the columns are points in time. The default concatenate adds the new array as more rows, whereas I want to add them as more columns. (E.g. each channel is getting more points over time, and I need to build up the waveforms.) So the easy solution is to transpose the two arrays, concatenate, then transpose back, as in the image. Seems unnecessarily intense.
I suppose one alternative would be to pre-allocate the full array, then use Replace Subset to put each sub-array in.
Any other quick, clever ideas?
TIA,
    DaveT
David Thomson Original Code Consulting
www.originalcode.com
National Instruments Alliance Program Member
Certified LabVIEW Architect
Certified Embedded Systems Developer
There are 10 kinds of people: those who understand binary, and those who don't.
Message 1 of 11
(2,436 Views)
Hi!
How does this look?
Message 2 of 11
(2,423 Views)
Nice! Thanks. I'll debate using that vs pre-allocating. Pre-allocating is probably (or at least used to be) more efficient, but your idea allows me more flexibility with changing how many times I concatenate.
Message 3 of 11
(2,418 Views)
I think pre-allocate is the best, but you can use Matrix operations to achieve your result.
Message 4 of 11
(2,412 Views)
Okay, I would be curious to know what you ended up using.
I focused on "(E.g. each channel is getting more points over time, and I need to build up the waveforms.)"
Message 5 of 11
(2,394 Views)
Is there any reason why you can't change your definition to "rows are points in time and columns are channels"? If it is just for graphing, there is a transpose option on the graph.
Message 6 of 11
(2,367 Views)
One more simple method you might add to your benchmarking tests.   Note: uses auto-indexing on both orig and new 2D arrays, so only valid when # rows cannot change throughout the run.
-Kevin P
Message 7 of 11
(2,365 Views)
Pauldavey
The data is from a Daq task, so it comes out with the given dimension definition. Switching it would just mean transposing, as per my original image, which is what I'm trying to avoid.
Message 8 of 11
(2,351 Views)
Thanks to all for the suggestions! It's great to see that the community is still strong and supportive.
Message 9 of 11
(2,345 Views)
I suspect that a simple transpose on a relatively small array is going to cost less than all the gymnastics of other techniques. In any case, it is worth considering:
  • How much performance is required - is the current performance adequate
  • Simple code is preferable to complex code that has a minor performance gain (unless it is absolutely necessary).
Message 10 of 11
(2,343 Views)
