how to dynamically control the indice of an array
Hi ,
In fact I have two request:
1/
I want to create an array that have different size? depending on user's request!
So I would like to be able to set the indice of the array so that allow the user to have his array with different ligne in is array (1D)!
On my test the number of ligne will be affected by an other application (a for loop used in an other part of my application)!
2/ Is it possible to have two loops "for" that command in the same time a sequence loop (with indexation)?
Tx
Message 1 of 11
(3,913 Views)
Hi akim_10,
which values shall the array elements have? You can use the "initialize array" function. What do you mean with your second point?
Mike
Message 2 of 11
(3,911 Views)
Hai,
Can you post some more details on what exactly is your requirement or some sample vi's
With regards,
JK
(Certified LabVIEW Developer)
Give Kudos for Good Answers, and Mark it a solution if your problem is solved.
Message 3 of 11
(3,902 Views)
My application is not done as I don't know how to do it! What i want to do is:
Create an array of numbers that will set the timer for diiferents points , for the moment i set a numeric value  for each timer of my sequence!
But I want to have only one timer set by an array that will follow the same loop of my points!
See file attached, the loop "for" is commanded by a txt file for different points and my timer for this point 10 ==> my timer will be then out of my sequence inside the "for" loop commanded by the array ousaide the "for" loop!
tx
Message 4 of 11
(3,894 Views)
I fear that I've misunderstood your intent but, in the event that I haven't, consider this.
The 'control' control I added would be the result "commanded by a txt file for different points".  The 'Timer delays' could be a control on the Front Panel or an array generated somewhere else.
Code Capture Tool
Message Edited by jcarmody on 03-09-2009 06:52 AM
Jim
Message 5 of 11
(3,857 Views)
In fact what i need is to create dynamically the array that will command the timer!
if I have 3 points ==> the array should be able to set 3 differents timing on timer
if I have 5 points ==> the array should be able to set 5 differents timing on my timer
That the reason I want to know how I could set the indice of the array (not by changing the form of the array on the front panel
Message 6 of 11
(3,838 Views)
That should be easy enough, after I know what the n different timings should be.  How do you know what they should be?  I'm guessing that you want them all different, otherwise you'd be able to use a scalar.
Jim
Message 7 of 11
(3,828 Views)
I think you may be confusing array terms here.  You wrote "set the indice of the array" but I'm wondering if you are talking about its size.  You use an index to pick an array element, but you're talking about dynamically creating the array based on the number of points - that's the size.
Jim
Message 8 of 11
(3,822 Views)
Yes exactelly, they should be different, so each value of my array should be the timing!
So if i have an array of 3 value ==> the user will be able to set 3 different timing...etc..
Message 9 of 11
(3,820 Views)
you are right, what  I need is to be able to set the size of my array !
sorry for this! so is there a solution?
Message 10 of 11
(3,806 Views)
