I have the same code to be run for all the ring controls.How to do this.I want to put the code inside the loop but only the controls name is to be repeated or changed.thanks in advance
In the file attatched I included the things I thought you could do. Since all the Rings are the same you can put them in an array. The operation you are doing is allways the same so I put it in an SubVi. Now you can easily use a loop to calculate the 8 differences you are looking for.
Hi friend Sorry for the inconvenience.I'm having only LV6.1 version.It seems you have compiled in LV7.So i could not able to open it.Find me a please.So that it'll be helpful for me.
Its great.you have reduced many things.But why all the values are not getting plotted in a single run as the previous one vi that i have sent.In this it is plotting one by one for every run.
