how to divide a long number into two and put them into two different column of excel
I need divide a long string number like:"12345678" into two "1234" &"5678" ,which can be disply in the two different waveform and write them into the same two different column at same time ,may I knidly know how should I do it?Thanks
(2,773 Views)
the following is the attacheed example
(2,772 Views)
Hi John,
when it's a string then use "Split string"...
When it's a number you may use quotient&remainder.
(2,762 Views)
