05-11-2006 06:33 AM
05-11-2006 06:44 AM - edited 05-11-2006 06:44 AM
You can do it like this
Just use the match pattern in the string palette. The string constants are in '\' mode to see the control characters which are \07 and \r\n for <CR><LF>
Hope this helps
David
Message Edited by David Crawford on 05-11-2006 12:45 PM
Message Edited by David Crawford on 05-11-2006 12:46 PM
05-11-2006 07:37 AM
hi david,
i try what u sugested but it's still dosent work.
regard's
eyal
05-11-2006 07:51 AM
05-11-2006 07:59 AM
hi david,
i have labview 7.1.
05-11-2006 08:05 AM
05-11-2006 08:19 AM
Hi david,
thank's for your example, but still i cant see the ascii chars.
i know that in dos (run->cmd) i can see in the end of the string the ^G and then enter , so the barcode is working good.
try to press[ctrl+g] in dos mode the computer will beep after the enter,but in labview it's[i think] asurtcut and when i try to insert the barcode
it's doing something maybe we need to disable the surtcut menu and then try it.?
do you know how to disable this surtcut?(it's not in the vi propertis, i try it ...not working).
regards
eyal.
05-11-2006 09:25 AM
Ah see what you mean. Not sure you can do anything about that.
Configure your barcode scanner to not output CTRL+G would be my next suggestion. Incidently, you would suffer the same sort of issue if you were scanning the barcode into excel. CTRL+G is GOTO in that application.
David
