how to display subvi string to main FP by using global variable??
Attach with my vi's here.
Any help here.
Thanks in advance.
regards,
Simon
(2,873 Views)
You could add an independent while loop in the main VI that reads the global every second (or so) and displays it in the indicator.
(Still, there are probably better ways to do all this ...)
(2,866 Views)
Thanks for the reply and suggestion.
Just come across why not put the whole subvi into my main although look bit messy.
Thanks once again.
(2,853 Views)
No, it won't be messy at all if you make a nice state machine and use a single while loop for everything. You don't even need the global variables. Simply update the string terminal outside the state case.
(2,837 Views)
