how to display array values on indicators
how should i get read of that mismatch \
Message 21 of 41
(2,174 Views)
Search and Replace String in the string palette.
Message 22 of 41
(2,172 Views)
what kind of connection i have to make on search and replace buffer
thank you
Message 23 of 41
(2,167 Views)
Please turn on Context Help.
If this basic function is so confusing for some reason, add the \00 to the format string of the Scan from String function. Be sure to enable \ Codes Display in order to scan for the correct character.
Message 24 of 41
(2,162 Views)
still im not able to get reed of the error by adding \00
Message 25 of 41
(2,156 Views)
Here it is with Search And Replace String
If you want to see how to add it to the Scan from String, attach your latest VI attempt.
Message 26 of 41
(2,155 Views)
done with search and replace
Message 27 of 41
(2,150 Views)
That's ridiculous. You want to replace from the VISA string that is read. Your code makes no sense.
Message 28 of 41
(2,143 Views)
please tell me what should be my input string to search and replace string should it be the *T%f or the output from read visa
Message 29 of 41
(2,138 Views)
Output from the VISA Read! The *T was just an example. It's the read that you want to get the data from, isn't it?
Message 30 of 41
(2,126 Views)
