how to display array using state machine
hi,
i tried display all required number in array at "input" state, but only can display current number. how can i fix that ,thank you
(3,570 Views)
Accepted by topic author jiannan
I send back the VI to you (saved in LV 2011...the typedef remains the same, you can keep yours)...Do you understand the modification ?
(3,557 Views)
thank you so much, that's is exaculty anwser i want, i found it's also work if i put output arry inside " input " state. is anything different leave array inside and outside of case structure?
(3,540 Views)
There's no difference indeed. You can put the array inside case structure.
(3,536 Views)
