how to display 2 signals in one chart
Holle all,
I've got a problem in vi.
We are using two types sensor ( color sensor, hall sensor )
Of course, we can display one signal, but, when we tried to display two signal at the same time, it didn't work.
I don't know what's wrong.
I will post our vi soruce bellow.
Please, save us 🙂
Message 1 of 15
(5,544 Views)
Bundle the two signals and send it to the chart.
Could'nt see the vi. Can send a lv2011 version code or a snapshot of your block diagram?
-kdm
Message 2 of 15
(5,542 Views)
Thanks for your reply.
This snapshot can take only one singal form DAQ.
So,we wanna get 2 signals in one chart.
Message 3 of 15
(5,537 Views)
I'm posting by phone so I can't open your VI but you should be configuring the DAQ Assistant to acquire two signals and wiring the output to a chart. I don't understand your shift register with a single waveform.
Message 4 of 15
(5,525 Views)
Use "merge signals" function from the functions palette, merge the two signals and pass to the chart.
Message 5 of 15
(5,513 Views)
Could you make a sample for this?
If i can see a picture or vi, then i will get better
because we are beginner.
Thank you
Message 6 of 15
(5,505 Views)
sorry . i don't know what did you say
could u make a vi program??
otherwise, if you send sample program??
already we tried to made two DAQ assistant but it didn't working
Message 7 of 15
(5,486 Views)
Just open the DAQ Assistant and click on 'Add' for the second channel. Done. The Merge Signal suggestion above is not used since you don't have two different signals to merge.
Message 8 of 15
(5,483 Views)
can you do like this one.. bundle the 2 data and connect it to chart
Thank you & Best regards
syrpimp
“You must continue to gain expertise, but avoid thinking like an expert." -Denis Waitley
Message 9 of 15
(5,475 Views)
 we tried to your solution.... but we got a error
Message 10 of 15
(5,467 Views)
