how to disable windows error?
Hi!
I want to disable or don't want to popup error messages which is generated by windows. Herewith i have attached file. If you run this file then it popup the error messages like Cannot find file:///C:/1.htm'. Make sure the path or Internet address is correct. and press ok then it opens the internet explorer. I want to disable this windows message and don't want to open internet explorer.
Please help me.
(2,864 Views)
Hi bhotu,
a simple solution for it could be to check by yourself if this file exists and only try to open it if it exists.
Mike
(2,855 Views)
Hi!
That's great idea that first i have to check file is exist or not. But again how to check that file is exist or not?
(2,848 Views)
You will need to check for the existence of the file first. Use the "Check if File or Folder Exists" VI that's in the File I/O->Advanced palette.
(2,847 Views)
That's great. you have solved my problem.
Thank you once again
(2,837 Views)
