how to disable screensaver in Agilent DSOX 2000 series
how can i disable the screensaver in Agilent DSOX 2000 series via labview?
Before initialisation i send a reset command to the scope over GPIB to ensure a clear state.
The annoying screensaver gets enabled with the reset command (agilents default is ON) so i have to
disable it. But how?
kind regards
system: Win7 and debian stable
(3,529 Views)
Read the Manual!
(3,525 Views)
can you tell me where in the manual you found the solution that i could not find there? And probably what the solution is?
I looked in this file: 2000_series_prog_guide.chm
Did you have a different command reference then i have?
(3,521 Views)
If it's not in the manual, call Agilent.
(3,518 Views)
If someone has a useful idea i am still glad to read about it.
I will post the final solution here when i found it out.
Message to Agilent was already sent, but i have no hope that they will answer soon (ever).
(3,515 Views)
