how to define an array of fixed length
hello, i have a basic application in which i need to define an array of size 19; and add 19 elements to it.
Once 19 elements have been written to the array, i want to start writing to the array from index 0.
It's like in C language, where-in you define array_size in init, and once the array is full, you overwrite the 1st element and so on.
i hope my question makes sense...
any help is appreciated.
Now on LabVIEW 10.0 on Win7
Message 1 of 8
(11,949 Views)
You can define an array of size 19 with Initialize Array.  For loops are good ways to index through an array -- learn about them.  If you want to simply replace a numbered element, replace Array Subset can work (the subset if an array of 1 element).  More experienced LabVIEW users might use the In Place Element Array Index/Replace Element, but you should start with the For Loop.  There are good tutorials out there ...
BS
Message 2 of 8
(11,939 Views)
Rotate 1D Array might be a useful function for you as well.
Message 3 of 8
(11,910 Views)
Hello LV_Enthu,
As Bob said, there is the two way of initialize array, you can follow any of the method which are displayed in image.
Vinal Gandhi, CLA
Message 4 of 8
(11,900 Views)
Hi Check out these VIs as per your discription. You can try your own method.
PBP
Labview 6.1 - 2019
Message 5 of 8
(11,864 Views)
Hi PBP,
the OP said to use LV8.0, so your LV2012 VIs aren't accessible…
Try this:
It defines an array with a certain size and fills it by overwriting the elements. Thanks to QR operation it starts over with 1st element once the array "is full"…
Message 6 of 8
(11,858 Views)
Ohh Sorry,
Please Find LV8.0 version.
PBP
Labview 6.1 - 2019
Message 7 of 8
(11,846 Views)
I hope this is in a useable version for you. Basically it covers a solution in which you write values at arbitrary intervals. I used an event structure to make my point, but it could of course be a state in a state machine or a while loop or something...
Like RavensFan suggested, it uses the rotate 1D array to rearrange your array. You take the last element and places it first, then replace it with a new value.
Jarle Ekanger, MSc, PhD, CLD
Flow Design Bureau AS
- "The resistance of wires in LabVIEW is not dependent on their length."
Message 8 of 8
(11,844 Views)
