how to create vector X(n) = [x(n) x(n-1) x(n-2).........x(n-N+1) in labview
i want to create an input signal vector X(n)  = [x(n) x(n-1) x(n-2).........x(n-N+1)
(3,772 Views)
Hi Rashi,
I think you need to read LabVIEW Basic -1. First read this all these issues will get resolved automatically.
Thanks and Regards
Himanshu Goyal | LabVIEW Engineer- Power System Automation
Values that steer us ahead: Passion | Innovation | Ambition | Diligence | Teamwork
It Only gets BETTER!!!
(3,766 Views)
This question is quite ambiguous, because you don't really define anything, but you could try "array subset" and "reverse array".
Can you give an actual example of an input array and desired output?
(3,752 Views)
i am implementing variable step size least mean square filter equation in labview
output error  equatyion e(n) = d(n)-X'(n)W(n) where X(n) is input signal vector X(n) = x(n) x(n-1) ...............x(n-N+1), ' denotes transpose.
(3,732 Views)
Check this document for LMS Filter algorithm
Silver_Shaper | CLD
(3,728 Views)
