how to create event driven timer
Hi everyone,
I'm using LabView 8 and wish to create a timer which starts when I press a control for the first time and shows time in milliseconds. The timer should stop and return to zero as soon as I press another control/Stop button or pass any condition to it.
Can anyone help around.
Looking for help,
Message 1 of 56
(24,306 Views)
What resolution and accuracy does this timer need to have? With a non-realtime OS like Windows any timer you create in software is going have significant inherent inaccuracies.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 56
(24,287 Views)
I want a timer which has resolution in 1 ms. One which can behave like a stopwatch, which I can trigger using a switch(say a Latch Boolean control) and stops on other boolean condition. Next time when again switch becomes active, it starts again from reset.
Message 3 of 56
(24,285 Views)
I would be real hesitant trying to get that fine a resolution with a software timer on a non-RT operating system. There are simply too many things that the OS can do to get in the way.
Mike...
LabVIEW Champion
Message 4 of 56
(24,278 Views)
Could you please clarify...how can I achieve it...can you give some examples??
Message 5 of 56
(24,275 Views)
As Mike said, you can't rely Windows to be accurate to the millisecond.  But if you are just using front panel Boolean switches to manually control the stopwatch then a few milliseconds here or there probably wont bother you too much.
If you're going to leave it running for days then you will need to consider that the value of the ms timer will wrap around to zero every 42 days (or something like that).
Troy - CLD "If a hammer is the only tool you have, everything starts to look like a nail." ~ Maslow/Kaplan - Law of the instrument
Message 6 of 56
(24,274 Views)
I don't have Labviw 8.2.1 ...I'm working on 8Smiley Sad
Message 7 of 56
(24,265 Views)
Message 8 of 56
(24,263 Views)
Here's another quick draft.
(If you don't neet to see the current time while it's running, delete the timeout case and the upper shift register and associated things.)
Message 9 of 56
(24,253 Views)
I would think the the human reaction time is much slower that windows overhead in event handling, that is pressing the button will have aloo accurate responses than 1 ms.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
Message 10 of 56
(24,226 Views)
