how to create custom project in LabVIEW 8
We can create VIs from the template in similar fashion i want to create a perticular folder hierarchy and copy some common VIs in perticular locations when i create  a new project. as in 7.1(or even in 😎 we had option to create blank VI or VI from template, is there any option to blank project or project from template.
If this feature is not readily available then can i develop a tool which can do the job? How?
Tushar Jambhekar
tushar@jambhekar.com
Jambhekar Automation Solutions
LabVIEW Consultancy, LabVIEW Training
Rent a LabVIEW Developer, My Blog
(3,070 Views)
You can only create an empty project.
Since the project file is a simple XML-File you can create templates for some sorts of projects. You are able to create a VI which will allow you to manage template projects. I don't know if you can integrate this into the "Getting started" window of LV.
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(3,062 Views)
Hello!
You can do more than just creating a blank project with the VI server -- check out the example "Add files to project" from the NI Example Finder (help->find examples->new to lv 8->general).  The other post was correct though -- it is just an XML file that you can manipulate how you choose.
Hope it helps!
Travis M
LabVIEW R&D
(3,037 Views)
