how to create a running integral
I have an experiment set up where I am sweeping across a specified voltage range and collecting capacitance measurements. I have the capacitance plotted as a function of the voltage. I would like to know how I can integrate the plot I have and display it on its own separate graph as a function of voltage. Thanks for your time.
(3,628 Views)
(3,617 Views)
Thanks for the reply! Will using "integral x(t)" be able to display a continuously updating graph if I wire the output to an xy graph?
(3,607 Views)
Well you need to build the graph using the same x. You might try the ptbypt version if you get the data one point at a time.
(3,589 Views)
