11-17-2014 09:24 AM
Hi all,
I have a case in which I want read in a signal analog input (voltage) from a photodiode, I want to create a 2 sinewave signal locked in with same phase as the input signal and output them as analog output to my 2 laser diode. the frequency of the input signal is low aroud 15 Hz , the 2 output signal i want to be around 120 hz and 150 hz .
I am using USB - 6003 daq card.
I have created a vi to see the input signal but I dnt know how to create 2 signal from the waveform generator locked in the phase as the input signal. I have seen a PLL vi , but dont know how to use that with my program.
can any one tell me how to proceed.
thanks
AG
11-18-2014
12:13 PM
- last edited on
12-15-2025
03:56 PM
by
Content Cleaner
Hi AnkitG,
Here are a couple of links that might help you understand a little more how the PLL work and a way to synchronize the task to perform a PLL.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P9T3SAK&l=en-US
http://digital.ni.com/public.nsf/allkb/2F675A9F2162EA24862572570059A308?OpenDocument
Also, you should be able to find a lot of examples on how to accomplish the synchronization of tasks on the community, if you consider that the only consideration is that both must start at the same moment.
I hope, these examples might show you some useful concepts:
http://digital.ni.com/public.nsf/allkb/EBD603683446EC13862575B3006A63A2
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8b6SAC&l=en-US
Luis C.
