how to copy the vi's names of a labview library
Hello all,
is there any way to list the names of vi of a labview library to store them in a text file ?
thank you for your help 🙂
(2,115 Views)
Accepted by topic author Chakib11
In the particular case of a packed library, there is a VI called "Get Exported File List.vi" from the built-in Packed Library Utility (just type its name in the quick drop to find it). It lists all public VIs from the packed library given its path:
For more general cases with a non-packed library, you can use VI server to access its members:
Raphaël.
(2,097 Views)
I see you have an answer already.  That's what happens when you don't press [POST] for a few hours.
Bill
CLD
(Mid-Level minion.)
(2,051 Views)
