how to convert radian to grade lV6i
HI, the outcome of tangent is in radian.
But how to convert this easily in grade using labview 6i.
I tied UNIT to convert but the outcome is not the same as i do it with my calculator.
Please help.
Maybe it's simple but i'm stuck searching right now.
Thanks.
(4,973 Views)
See attached image. Unit conversion works (you first have to "tell" LV what unit the unitless number is, then you can convert it). But it's as easy to use math functions.
(4,971 Views)
Thanks very much.
I also tried something like that but was not correct.
I'll give it a try.
Thanks again.
(4,965 Views)
