how to convert array of strings into a tree?
I have been given a task in which I have to convert an array of strings into a tree.
For eg. if the first element is xxxx/yy/zz (here xxxx is the parent of yy & yy is the parent of zz)
             and the second element is xxxx/yy/ww... Here I should compare all the elements of the array and make a tree out of it.
Here the input will be already given.
Thank You.
(2,680 Views)
Accepted by topic author ashganguly
Check out this topic. It may be what you are looking for
Tree Control - Parse array of strings to
(2,633 Views)
