how to convert analog scalar into digital value
I have the DAQ connected to a system that sends a digital 0 or 1 through the analog BNC connector. If I use DAQ Express VI, I can convert the dynamic data type into a boolean (rather than scalar) array so it's easy to check if the value is 0 or 1. Because I'm running the VI in real-time, I can't use dynamic-to-boolean array conversion. The output I get is a 1-D waveform array which will give me scalar values. The task has a voltage range of -10 to 10 mV. How can I convert that into a 0 or a 1? Should I set the voltage range to 0-5V and simply have an if statement that checks if the value is, let's say, greater than 2.2V (which will mean it's a binary 1)? Is there a better method?
Thanks.
(3,280 Views)
Hi abdel2,
It sounds like you are trying to measure digital data from your system. If that is the case, you should be able to connect to a digital input line if your DAQ card had them. Then you can set up a digital acquisition in LabVIEW that will interpret the signal as a boolean input.
If you are not able to do this, you can approximate the digital behavior by reading analog data, and pragmatically determining a threshold (for example 2.2V), though this is a less efficient way to do it.
Stephen S.
Applications Engineering
(3,242 Views)
I guess digital lines would be better than analog but I am using BNC connectors right now. I need a wire connection for digital input. Maybe I'll replace them later but for now I'm working with analog connectors. I just implemented an amplitude check (>2.2 V = 1) and it seems to work great.
Thanks.
(3,217 Views)
