how to convert a sample from labview 5.1 to labview8.0
I have a sample from the manifacture which was programmed using the labview5.1 but now I use use the labview8.05 . Can anybody help me to convert the sample from labview5.1 to labview8.05 , thanks
(3,388 Views)
Hi alane,
here you go. It's missing the ActiveX component...
Btw. you surely use LabVIEW8.5 Smiley Wink
Message Edited by GerdW on 09-07-2009 03:20 PM
(3,375 Views)
Accepted by topic author 92395
Here it is upgraded, although it is missing some subVIs and an ActiveX control.
(3,373 Views)
thanks you two , I will try another invoke and property node and see if it can do something to the instrument , by the way the attachment is the AtiveX , the extend file name .ocx is not valid in the forum , so i modified it to .docx. so you have to modify it to the .ocx
(3,358 Views)
Hi alane,
we don't need this ActiveX, it has to be installed on your computer to run your vi.
Hint: next time you should just zip the file, this way it will be (most probably) smaller and will pass the forum filter Smiley Wink
(3,351 Views)
