how to convert a html document to xml document in labview?
Hi
I want to generate a xml document of the test results. is it possible to do it using labview. Is there any way to convert the html document generated through labview to xml
(3,380 Views)
There are XML functions on the Advanced>Data Manipulation palette and an example called Write Data to XML File. OpenG also has an XML toolkit.
(3,380 Views)
