Some courses and learning paths on NI Learning Center may not appear on learner dashboards. Our team is actively investigating.
If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
how to convert a double to boolean array
I'm looking a way to convert a double in a boolean array of 64 elements and viceversa.
Message 1 of 12
(6,548 Views)
Please test this example.
Good luck!
Message 2 of 12
(6,548 Views)
Well, I guess that your boolean variable shall be true above or below a certain specified value.
You can use the > or < function on the double array. The result should be the boolean array you are looking for.
Stephan
Message 3 of 12
(6,548 Views)
The version posted by miguel doesn`t work properly on my machine.
Try this modified version. The problem was the coercion of the bouble (8 byte) to a U32 (4 byte) in the "number to boolean array" funtion.
Shane
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
Message 4 of 12
(6,548 Views)
maybe i didn't undertand your answer or you didn't undestand the question: only 1 double in an array of boolean...
Message 5 of 12
(6,548 Views)
it doesn't work: the number to array works only for 32 bit!!!!
Message 6 of 12
(6,548 Views)
Thankyou: this maybe works but i founded something simpler, if You are ineterested, i'm working on this, to find a way to reverse it.
Message 7 of 12
(6,548 Views)
Well, I thought you are looking to process a threshold value fast, but as I have learned from the other postings you are looking for a method to convert a double value to a binary value (which is represented as a array of boolean).
Sorry for my misunderstandig!
Stephan
Message 8 of 12
(6,548 Views)
You`re doing basically the very same as in my example. Granted, it looks simpler, but the operations are basically the same.
Also, my version has already incorporated a method to reverse the operation. Look carefully at my example, and you`ll see that the DBL is re-created from the boolean array.
Shane.
Message 9 of 12
(6,548 Views)
In addition to these examples, I also thought this link might be useful to you.
http://digital.ni.com/public.nsf/websearch/DD5AFE8E829DC16D86256BDF005E1F95?OpenDocument
Good luck,
FerozP
Message 10 of 12
(6,348 Views)
