how to convert 1D array fo double to 1D array of variant?
I want to use the KNN vi in machine learning toolkit  but the example input require a data type of 1D array of variant. How can I make the convertion? Thanks.
(3,607 Views)
Hi winnie,
maybe just like this:
(3,603 Views)
Thanks for your answer, I try your method and it works for convert a 1D array of double control to 1d array of variant indicator.But I want to use the variant array as input of the KNN vi,when I change the above indicator to array and connect it to vi and run the program,nothing happen. I don't know why...
(3,571 Views)
I mean chance the variant array indicator to control to connect it to the input of the vi.
(3,570 Views)
Just wire the Array of double to the input connector that is an array of variant.  LabVIEW will take care of the conversion for you.  That is what Gerd was trying to show you.
(3,563 Views)
Oh I see it. Thank you.
(3,558 Views)
