how to control a cylinder with an optical sensor
First of all,  I´ve been working hard to make this control, and I'm a very beginer in labview, and also in programing. I want to control an hydraulic cylinder.I also have an optical sensor (with an output of 1-10V) that reads this distance, so, for example, I want to create a boolean value when the cilinder is at the point equals to 350 milemeters that will make it go forward and, when it arrives to 400 milimeters a new boolean pulse is generated and makes the cylinder come backward.
The cylinder will keep going and coming. I alredy understood how to generate this pulse, My problem is to hold this pulse while the cylinder is going, or coming
I want to do this with a DAQ 6009 and use two digital output to control an electronic board that I created, that will control relays that will control the valve.
When the first digital output is on, the second is off,  and vice versa.
Whats the easier way?
For this logic I think it's necessary a control like this, that "memorizes" the boolean "pulse", anyway, if someone teach me something that don't need this "memorizing tool" I will apreciate, but, I'd like also to know how to do this "memory".
This is all.
Sorry for my bad english, and hope someone help me.
Thank  you!
(2,412 Views)
(2,383 Views)
The following links have options to you learn some LabVIEW Fundamentals. How I saw you are from Brazil, the first link is in portuguese and second is in english.
http://search.ni.com/nisearch/app/main/p/bot/no/ap/global/lang/en/pg/1/q/labview%206%20horas/
http://www.ni.com/academic/labview_training/
Abel Souza
Abel Souza
Engenheiro Eletrônico
LabVIEW User since 8.5
(2,350 Views)
