how to control 2 motors
hi every body
i am working in joystick to control two motors
i used DAQ 6009 and syren to control the speed and direction
i did the program but i have one problem
that when i move the joystic forword or backword only one motor is moving
and when i move the joystic left or right the other motor is moving
i connected x-axis to a0
and i connected y-axis to a1
the DAQ just has a0 and a1 output
my question is
how to move two motors at the same time
that for example when i move the joystick forword the two motors move clockwise and when move backword the two motors move counter clockwise
please i need help
thank you
Message 1 of 15
(4,135 Views)
Hi Sara,
"i connected x-axis to a0
and i connected y-axis to a1"
What would happen when you "connect" Y axis (joystick for-/backward) to both outputs (a0/a1)? Would that solve your problem?
Message 2 of 15
(4,128 Views)
hi
no i can't connect y-axis to both because there is error appear
thank you
Message 3 of 15
(4,126 Views)
Hi Sara,
i would be much easier to help, if you could provide more details...
What kind of error? Example VIs? What have you tried so far?
Message 4 of 15
(4,121 Views)
hi
the error that i cannot connect the y-axis to bothe a0 and a1
i tryed to connected each axis to both a0 and a1 but i cannot
and this is the problem
thank you
Message 5 of 15
(4,115 Views)
Hi Sara,
"i tryed to connected each axis to both a0 and a1 but i cannot and this is the problem"
Again the same question! Please provide more details!
You can't connect. Ok. But why can't you connect? What is the error you receive? Can you attach an example VI?
Message 6 of 15
(4,111 Views)
hi
this is the prentscreen of my vi
and the error appear when i connect y or x axis is that there is one data and two tasks
Message 7 of 15
(4,105 Views)
Hi Sara,
why can't you attach the VI? So you have to make the changes on your own...
What is hidden in the FALSE case of all those case structures? Surely a FALSE constant, I guess Smiley Wink
Have you ever heard the word "Rube-Goldberg"? There is a special thread here in the forum about it!
-You have a construct like IF TRUE THEN output TRUE - 4 times in this litte VI. Please remove it and connect the output of the comparison directly to the LEDs.
- The "IndexArray" function can be resized to show more outputs. So you can put the functionality of the 3 IndexArray nodes into just one. Well, you could also replace the whole ClusterToArray+IndexArray with just one UnbundleByName function...
Why can't you connect the input of both DaqAssistants with the output of one Add function???
Message 8 of 15
(4,065 Views)
hi
thank ypu very much for your comment
all what you said are correct
but
still my problem is with DAQ
i didnot under stand
do you mean
i should connect x and y to an add function then to DAQ
if you mean this i tryed this solution but there is error appear sais min is 0 and max 5
because the output should be 0V to 5V
thank you
Message 9 of 15
(4,035 Views)
Hi Sara,
at the moment you have connected the input of the DAQAssistant with an ADD node (x + 2.5), one ADD for the X-axis, the other for the Y-axis.
You said you want to connect both DAQs with the Y-axis. Hence my suggestion to connect the output of the ADD, that is wired in the Y-axis dataflow, with both DAQAssistants...
Please attach your VI (the real VI, not a picture...) for easier helping!
Message 10 of 15
(4,027 Views)
