how to continuous data acquisition and save to an excel file using vc++
I’m trying to build an MFC application with MSVC++6, where I would continuously acquire
samples from 2 channels of a USB-6289. I’m using the DAQmx C functions.  I
use the following codes to continuously get data:
        DAQmxErrChk(DAQmxCreateAIVoltageChan(taskHandle,"Dev1/ai0,Dev1/ai1","",DAQmx_Val_Cfg_Default,-10.0,10.0,DAQmx_Val_Volts,NULL));
        DAQmxErrChk(DAQmxReadAnalogF64(taskHandle,1000,-1,DAQmx_Val_GroupByChannel,data,2000,&read,NULL));
        DAQmxErrChk (DAQmxRegisterEveryNSamplesEvent(taskHandle,DAQmx_Val_Acquired_Into_Buffer,1000,0,EveryNCallback,NULL));
        DAQmxErrChk (DAQmxRegisterDoneEvent(taskHandle,0,DoneCallback,NULL));
 static int32 EveryNCallback(TaskHandle taskHandle, int32 everyNsamplesEventType, uInt32 nSamples, void *callbackData)
    int32       error=0;
    char    errBuff[2048]={'\0'};
    static int  totalRead=0;
    int32       read=0;
    float64     data[1000];
    // DAQmx Read Code
   if( read>0 ) {
    fflush(stdout);
        Error:
    if( DAQmxFailed(error) ) {
        DAQmxGetExtendedErrorInfo(errBuff,2048);
        DAQmxStopTask(taskHandle);
        DAQmxClearTask(taskHandle);
            return 0;
static int32 CVICALLBACK DoneCallback(TaskHandle taskHandle, int32 status, void *callbackData)
    int32   error=0;
    // Check to see if an error stopped the task.
    DAQmxErrChk (status);
Error:
            //MessageBox("errors in DoneCallBack");
        //MessageBox(errBuff);
    return 0;
I have two questions:
1. how to save the data into an excel file? Can anyone show me some sample codes please?
2.Are the data acquired from the two channels simultaneously? If I set the starting time at 0, sample frequency 1khz, can I directly multiply the sample number by 0.001 to calculate time (as shown below)?
Time    channel1  channel2
0.001    d11           d21
0.002    d12           d22
Thank you!
(2,845 Views)
You aren't going to get much help with Visual C++ programing when asking questions in the LabVIEW forum.  Smiley Wink
Try the Measurement Studio for Visual C++ forum.
Message Edited by Ravens Fan on 12-05-2008 04:24 PM
(2,843 Views)
This is a duplicate thread. The current thread can be found here.
Dan King
(2,810 Views)
