how to connect 2 wire sensor to DAQ
I need to connect a 2 wire and 3 wire sensor to the NI PCI 6514 DAQ board.
How do i do that?
Will the sensor work if i connect one wire to the input port and the other wire to the corresponding COM port? (ex. P0.0 and P0.COM)
What is the solution in case of 3 wire sensor ? i have no clue on this...where should i connect each wire to?
Kindly help me out.
Its urgent.
Regards
Grugh Mike
Success is Everything !!
(4,037 Views)
Hi Mike,
you better read the manual of your sensors. They usually explain how to connect them...
2-wire-sensors commonly use the current as signal, while 3-wire-sensors usually use power supply for 3rd wire and give a (ratiometric?) voltage signal on "middle" pin...
P0.0 seems to denote a digital input - it can be tricky to use an analog sensor with that input! Smiley Wink
(4,025 Views)
Dear GerdW
Thank you for the reply.
I read the manual--> I am using the proximity sensor from FESTO SME-8-K-LED-24
It has three wires, blue, brown and black.
It should be connected to the 6514 card.
If i am using bank 0; then the P0.0 and P0.COM will my required pins.
Will it be ok of i connect brown and black to P.COM and blue to P0.0?
Kindly advice.
Also what should be the required rating of P0.COM to be supplied external ?
Will a 24V, 1.42A DC supply be ok?
Kindly help.
Regards
Grugh Mike
(3,999 Views)
Hi Mike,
well, there are schematics in the manuals - ot hard to find that information...
brown = +voltage
black = P0.0
blue = ground
For your P0.0 input you should use a supply of 5V (TTL-compatible), propably available on your card. Connect the supply voltage with your brown wire. (Maybe switch to the P6 or P7 bank, as they provide 5V!) Maybe you will need a pullup or pulldown resistor to assure clear voltage potential
when the FESTO switch is open.
(3,989 Views)
