how to configure a shell and tube heat exchanger with Lab VIew to get data
You may want to read Pressure Measurement Basics. It sounds like you are using a pressure transducer with built-in electronics, so the bridge scaling doesn't apply - is that correct? What type of pressure transducer is it? If this is the case, then you should configure it for a voltage measurement, then set up a custom linear scale to convert it to pressure - or do the math in your LabVIEW code.
Message 21 of 23
(679 Views)
thanks is there one of these for water flow measurement basics
Message 22 of 23
(672 Views)
Not that I've seen, but you can search on the NI site and see if you find one. That's how I found the pressure measurement link.
Message 23 of 23
(669 Views)
