how to combine three program
Hi everyone
   i have design three program base on RS232 to control a dispense unit's dispense time dispenser pressure, and its dispense programe,which use for a printer. but i do not know how to combine this three programs in one front panel, can set the time and pressure
anyone can help with this?
(3,632 Views)
Make a program containing all the common communication code. Now use a case structure to select between the three different data constructs.
Your code is overly complicated. There is way too much unnecessary stuff (e.g. (1) Use a U8 array diagram constant instead of building U8 arrays from dozens of scalar U8s. (2) In some places you convert to a string and back to U8 array for no reason at all, (3) etc...)
(3,620 Views)
my code is depend on the instruction book of dispense unit, i think that better use a SUBVI to combine them
(3,611 Views)
I don't know what that means. Can you explain?
(3,607 Views)
Yes for example the command for the pressure is stx 0EPH_ _CH200P[][][][]?? ,[][][][] means the pressure,?? is the checksum. therefore if want to set the right command should calculate the cheksum. my program include these
(3,605 Views)
can you teach me how to combine them on one front panel?
(3,590 Views)
