how to combine 2 strings into 1
Hello all,
Here I have a question about data processing. Now with a UDP open and UDP read vi I keep
receiving UDP messages with different titles (for example $1, $2, $3....) from 2 devices. The 2
devices are almost syncronized and send UDP messages at almost the same time (less than
one second of difference in time). With a Obtain notifier vi I can receive these messages one by
one and send them to another loop. Now what I want to do is to receive these messages TWO
BY TWO! Becasuse they are from 2 devices, firstly two $1 messages, then two $2 messages
and so on. I'd like that the obtain notifier could receive messages two by two, namely the messages
with the same title could be received together! I can't use a concatenate string because the received
messages will accumulate. So what should I do, any idea?
Chao
Message 1 of 18
(4,907 Views)
Actually I don't need to combine all messages with all titles two by two, only the message with title $1
because that's the only type of message I'm interested.
Message 2 of 18
(4,901 Views)
If you use a common queue instead, both devices can feed the same queue, and then can be dequeued in your other loop.
Bill
CLD
(Mid-Level minion.)
Message 3 of 18
(4,894 Views)
Sure you can use concatenate string.  I assume when you say "messages can accumulate", you are talking about storing the string in a shift register.  You can also use a select statement to determine when to store the string in a shift register or store an empty string in the shift register.
It is difficult to give any advice without seeing the code that you have now.
Message 4 of 18
(4,893 Views)
Hmmm... your solution is so different than mine.  Maybe I misunderstood the question?
Bill
CLD
(Mid-Level minion.)
Message 5 of 18
(4,890 Views)
I agree that you probably really want to use a queue.  This way you know you are not overwritting messages.  But we really need to see some code to understand properly what you have.
Message 6 of 18
(4,879 Views)
Thanks for the reply!
here is a simplied vi of my code. I tried to put a concatenate string at the place
where I put 'here' to do the combination but nothing changed. The Num of message
shows still 2 messages instead of one when 2 messages with title '$ES' come together.
So do you have further suggestion?
Message 7 of 18
(4,877 Views)
Sorry my post above with my code is for you. But anyway that's my code and what
I want to say as comments. So any suggestion?
Message 8 of 18
(4,876 Views)
Thanks for the suggestion. But as far as I know, the queue function works similar to notifier, right?
And in my code above, do you have any idea how could I use queue and dequeue? Shall they have
the same scheme as the notifier has?
Message 9 of 18
(4,871 Views)
first of all ...i would get rid of that "stop/abort" vi? and use a local stop control for the second loop and change the control mechanical action to "switch when pressed"
Message 10 of 18
(4,866 Views)
