how to change the string indicator text output size?
How can I change the output text size in the string indicator?
I am using the string indicator as my test result output display window,
and some cases I want using big text size to emphasize the pass/fail status.
Can someone show me how?
Thanks.
(9,036 Views)
You can do it via the menus for a control or an indicator. You can also do it pragmatically using a property node.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(9,032 Views)
Thank you for your reply.
Actually I meant was that when I print out the test output most of time,
it will be normal font and at the last line I like to have a large font to indicate global pass/fail.
how do I do that?
For example,
test1 pass
test2 fail
test3 pass
Overall test: FAIL
(9,022 Views)
There is a text.selection property you can use.
See this thread for a good example.
(9,007 Views)
