how to change numeric indicator background colour?
hi,
i am acquiring 60 channels of temperature data, that will display on numeric indictor under cluster. user will set the alarm  for temperature level that has to change the back ground color accrodingly.
example: below 60 - Yellow
              above 75- red
how to access these properties under cluster control...?
find attachment
Balaji DP
Message 1 of 13
(8,918 Views)
I think the property node you want is Numeric Text -> Text Colors -> BG Color.
Message 2 of 13
(8,913 Views)
You can use a property node:
You can do something similar to change it to red.
Edit: I red the numbers too fast, so the above image is incorrect. You would simply replace the "greater than" with "less than" and make the numeric 60.
For red, keep the "greater than" and make the numeric 75.
Cory K
Message 3 of 13
(8,909 Views)
yes, i want to change the background colour of nueric text......
Example
find attachment
Balaji DP
Message 4 of 13
(8,905 Views)
Consider using a customized color ramp.
See attachment.
Message 5 of 13
(8,895 Views)
hi,
i am using labview 8.6 version.. can you downgrade your code and send back to me?
Balaji DP
Message 6 of 13
(8,893 Views)
Here is an example for version 8.6
Cory K
Message 7 of 13
(8,890 Views)
nice, thank you....
but how to do this under cluster control...?
find attachment
Balaji DP
Message 8 of 13
(8,883 Views)
You could iterate through the controls using a for loop.
Cory K
Message 9 of 13
(8,869 Views)
no, i could not able to find out this property
Balaji DP
Message 10 of 13
(8,861 Views)
