how to change file access (e.g. Read Only) using ActiveX?
Does anyone have experience in opening a old or new excel file and then save it as a "Read Only" file?
There is a function "changefileaccess" in excel which also shows up in the function list of the labview invoke node of a workbook.   I am attaching a labview file here that I used for testing.
Thanks in advance,
Luke
(3,073 Views)
You don't need to use ActiveX. You can use the file permission functions within LV to modify the read-only state of any kind of file.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,063 Views)
Mike, Thanks for your help,
Luke
(3,044 Views)
