how to change button image without run the vi
hi,
     i want to change button image when i move mouse above my image but i not run my vi.
Message 1 of 15
(4,314 Views)
Perhaps someone who knows more will correct me, but I think the short answer is "you can't" and the longer answer is "for something to change on your front panel due to mouse positioning, you need to have at least something running. It doesn't have to be that VI - an XControl, for example, is running once it is placed on a front panel and so it could track the mouse position, have an event case that would monitor for a cursor enter event, then change the image displayed on some part of the control"
Maybe if you gave a bit more information about what you're trying to do (especially why you don't want to have your VI running) it would be easier to give a useful answer?
GCentral
Message 2 of 15
(4,286 Views)
System booleans change with mouse-over (& you can easily customize the images), but it only works when the VI is running.
Why do you need it to change when the VI isn't running?
Message 3 of 15
(4,234 Views)
You may be able to press ctrl+M to see what the front panel will look like when running. Press ctrl+M again to go back to edit mode.
Message 4 of 15
(4,224 Views)
Edit mode has no purpose for the end user, so the solution is an application that is always running, but might be in an idle state when nothing needs to be done.
Yes, please explain why there is a need to change the hover picture in edit mode.
(An x-control as suggested might work, but is probably not worth the effort. I have not tried)
Message 5 of 15
(4,220 Views)
This actually work for the system buttons, some of which change color when hovering (after switching to run mode without actually running), but I doubt you could leverage that for your purpose. System controls inherit from the OS and are not very customizable.
Message 6 of 15
(4,216 Views)
hi,
          see the below link "GET VIPM" Button . when mouse move above button green color is fill same functionally  i want but without run vi.
http://jki.net/tools
Message 7 of 15
(4,194 Views)
I'm fairly sure you're right on both counts. I'm pretty confident it's not worth the effort.
GokulGKM,
I think we understand what you want. We just don't understand why it needs to be without running. If the VI is running, this task becomes comparatively straightforward.
GCentral
Message 8 of 15
(4,190 Views)
hi,
        i know it is possible while run the vi.but my aim is reduce the  program memory for some small applications.
Message 9 of 15
(4,183 Views)
Hi Gokul,
So the VI is still in "run mode" - even when it is just a "small application"…
Please explain with clear descriptions WHY you need to achieve this without running your VI!
Message 10 of 15
(4,180 Views)
