how to chang cluster of 2 elements( 2 measurement data 1 D array of (double[64-bit])) to dynamic data?
I need to do FFT transform, the input data type for FFT transform is dynamic data type, but the waveform from XY graph which time value is set by X axis and amplitude is bst by Y axis.
thank you for all your help
jing
(3,187 Views)
Hi jing,
can you please upload a vi with the information you currently have?
Mike
(3,182 Views)
thank you very much Mike!!
(3,166 Views)
maybe this one is much clear for my problem. very appreciate for your help!
(3,165 Views)
Hi jing,
you have to create a waveform. I changed your example. if your time values do not have the same dt you have to interpolate it first.
Mike
(3,159 Views)
ah!!!!!thank you so much for your help!!!my problem is solved!
I am a new to labview, this problem bothered so many days, so much appreciate for  your help!!!thank you again!!!
if you like I want to be friend with you, my name is Jing WEN, I am chinese, now I am studying in munich Germany.
my MSN:weixuan0713@hotmail.com
Thank your so much!
JIng
(3,152 Views)
