how to bring data from ethernet cable to LabVIEW?
yes sir i ve SDK with me..... pls give me idea for getting data from the ethernet cable and use them in LabVIEW .........
Message 11 of 12
(897 Views)
Like I said, you need to;
1 - determine the telegram protocol of your microcontroller - i.e. read the documentation - what commands to you need to send to it in order to receive the data you need?
2 - send the interrogation telegram commands over TCP -  you can use TCP Open Connection, TCP Write, TCP Read, TCP Close Connection
For example, ;
Use TCP Open Connection (with the correct IP address and port number of your device) to open a connection to your microcontroller
Send a Query Telegram (depending on the telegram protocol of your device) using TCP Write
Recieve the response using TCP Read
Then close the TCP connection using TCP Close Connection
Peter
Message 12 of 12
(887 Views)
