how to append to an array
i have a true false case inside a loop and each time
it pases through a false case . i pull out one value from the array(external). i would like to know if some one can help me in telling me how to append an element to an exisiting array or to create a array inside the false case structure.
THanks
(3,188 Views)
hello, well, I dun really understand what you wanna do. Here's my guess. Hope it helps 🙂
Cheers
ian.f k
SG/MY
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
(3,188 Views)
add on, you might consider initialise an array should you are working with a large array. Also, you may also stream them to file.
Ian F
依恩与LabVIEW
(3,188 Views)
Thanks IAN
i think it is ging to work that way .i tried that way but forgot using the shift registers.
thanks any way
i really appreciate it.
have a nice day
takecare
(3,188 Views)
You're most welcome.
Cheers!
Ian F
依恩与LabVIEW
(3,188 Views)
