how to add (multiple) cursors programmatically in an XY graph?
I am building an XY graph. then I would like to add cursors at certain locations (positioned on x axis) I determine through a program.
How can I add cursors programatically?
Thank you.
(7,529 Views)
Check out this thread:
http://forums.ni.com/ni/board/message?board.id=170&message.id=245120&query.id=17462#M245120
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
(7,527 Views)
Thank you, but the thread is not good enough. The answer provided by Evan is closest to what I have but not good enough.
I have no cursors on the graph before I start the program. The program draws an XY graph and then determines certain locations on X axis where I want to input cursors. The number of cursors is different every time. How could I add or create cursors on the XY graph starting with no cursors in the beginning? Then, how can I clear the cursors if I need to?
(7,523 Views)
Initialize a cluster array (CrsrList type) with as many cursors as you think you would ever need.   Setup your cursors dynamically, then delete the unused cursors (array elements) and then update your CursorList property.
Message Edited by vt92 on 03-20-2009 04:04 PM
(7,516 Views)
I think I'm on the right path but I still can show only one cursor. Could you be more specific?
(7,506 Views)
The graph has a property called CSRLIST, which you can set.
It's an array of CURSOR clusters.
Build each one the way you need it (Position.X, Position.Y, Color, etc.).
Build them into an array.
Assign the array to the CSRLIST property.
Enjoy!
Steve Bird
Culverson Software - Elegant software that is a pleasure to use.
Culverson.com
LinkedIn
Blog for (mostly LabVIEW) programmers: Tips And Tricks
(7,500 Views)
