how to add an automatic cursor on an xy-graph
hello, I was wondering if there were any property nodes on a graph that would alow for a cursor to autmatically scroll across a graph... basically, I'm loading a bunch of static data to an xy-graph.  And I want a straight line, perpendicular to the x-axis, to move across my static data, updating once a second... so I have an hour of static data, and I would like a cursor to move once a second across my data... I can't get a property node to do it... any suggestions?
much thanks!
(3,732 Views)
Accepted by topic author Fibo
First you need to add a cursor then use the property node for the position, like this
Rodrigo Cuenca
www.cidesi.com
(3,720 Views)
There are properties for ActCrsr (active cursor) and Cursor.PosX that you could use.
(3,719 Views)
Thanks for the responses... is there anyway to do this without adding the cursor legend? I just want the plot to display, and I can't get the property nodes to work, here's a simple VI of whatI'm trying to do... well it's not working, but that's what I'm tryign to use
(3,715 Views)
Nevermind, I got it, I added the cursor legend, used it to make a cursor, then removed teh cursor legend, and teh cursor stayed... thanks for the suggestions
(3,713 Views)
You need to create the cursor first, select visible items> cursor legend, then add the cursor right click in the cursor legend create cursor, and finally you hide the cursor legend
Rodrigo Cuenca
www.cidesi.com
(3,708 Views)
