how to add all element of array?
1-D array has N number of element .i want to sum all the element ,and the result is a number.
can you give me some example?
thanks.
Message 1 of 8
(3,798 Views)
Just use the "Add Array Elements"-function located in the Numeric palette.
Message Edited by becktho on 02-21-2006 12:58 PM
Using LV8.0
Don't be afraid to rate a good answer... 😉
Message 2 of 8
(3,791 Views)
Hi Ciomp,
this is dead easy... just have to know it exists 😉
have a look in the "numeric" section of the function palette (see picture)
Epictetus
Antoine Chalons
Message 3 of 8
(3,785 Views)
Hi Becktho...
Well done you are faster than me... by the way could you tell me how to get the attached picture to appear directly in the post Smiley Surprised ?
Many thanks...
Epictetus
Antoine Chalons
Message 4 of 8
(3,784 Views)
You'll find that there is an "Add Array Elements" function in the "Numeric" functions palette, this does exactly what you want.
If you can't find it - look up the function name in the "Help" index.
Mark.
Message 5 of 8
(3,782 Views)
TiTou
Thanks - that's the experience of a few more posts ;).
Adding the picture is no problem:
1. Post it as attachment (as you did)
2. Open the link in a new window and copy the url to the clipboard
3. Edit your original message
4. Choose "Insert an Image" from the toolbar and paste the previously copied url
That's it - just have a try with your previous post.
Thomas
Using LV8.0
Message 6 of 8
(3,779 Views)
Waow... that means you had time to all that before I post my answer... Smiley Surprised
Maybe that's why you are Proven Active Veteran and I'm only Trusted Regular Smiley Happy
Thanks alot 😉
Message Edité par TiTou le 02-21-2006 01:13 PM
Epictetus
Antoine Chalons
Message 7 of 8
(3,774 Views)
thanks a lot .
I am a new to LabVIEW.    I have another to ask you is that ,can you tell me about the differences between picture and IMAQ .    i know a color picture has RGB .how to  every pixel ' RGB?
thanks
Message 8 of 8
(3,765 Views)
