how to add a control to a Tab
Unfortunately, I have no choice for a selection, I am admin on this computer so that shouldn't be an issue?
Message 11 of 27
(2,269 Views)
Oh, never mind I have to select the item first, that is a major pain during development if everything is always locked and I have keep unlocking something every single time I want to move it?
Message 12 of 27
(2,266 Views)
That's why no one ever uses this feature, controls aren't locked by default, you have to make an effort to lock them, and then an effort to unlock them.
Message 13 of 27
(2,262 Views)
No.  Nothing is ever locked up.
Only if you intentionally locked it, or unintentionally because you clicked the wrong thing while doing something else.
Message 14 of 27
(2,261 Views)
Nothing is locked by default.
Message 15 of 27
(2,259 Views)
Ok nevermind agian, it still does not work, If I draw a box around a single item then as soon as I select the menu the item becomes unselected and I have no choices again. If I select a group of them like two buttons then all I can do is Lock them...lolClipboard01.jpg
Message 16 of 27
(2,258 Views)
Accepted by topic author rr1024
Apparently you have to draw box around the item to move it, you can't just click and drag it...wow...
Message 17 of 27
(2,253 Views)
That is definitely not true.
Message 18 of 27
(2,251 Views)
Definitely not the solution to your problem.
You just need to make sure you have the correct cursor showing when you click on it.  The arrow cursor is the cursor you want.  If you move too far and get the pointing hand cursor, then clicking will operate the control as opposed to selecting it.
Message 19 of 27
(2,240 Views)
Auto-tool strikes again.
Okay not so much, but LabVIEW by default has a thing called auto-tool on, where it will select the tool it thinks you want based on what the mouse is over.  It takes some getting used to, and you need to more or less change your habits to convince the tool to be the tool you want.
For this reason I am a developer who chooses to turn auto-tool off and select the tool I want, the overwelming majority of developers use auto-tool without much trouble and I'm sure if I forced myself I could change tool.  For those not using auto-tool you can hit tab over and over to get the tool you want, or press spacebar to switch between the two common ones.
To mess with auto-tool, or even to select a tool manually, you can hold Shift, and right click the block diagram or front panel.  This brings up the tools menu, and here you can turn auto-tool on or off, or pick the tool you want.
Message 20 of 27
(2,205 Views)
