how to add Windows based computer to a project
As it is the first time I'm facing such a problem I need your help.
I'm building an application for a WIn7 based computer. This computer has DAQ device inside. Is there an option to see this computer from Project level and run vi's on it? Building exe, starting it on the computer every time I make some change in the program takes too long.
Przemek
(2,611 Views)
Let me see if I understand your problem.
You have a PCI Daq board and you want to build an exe that will use the resources from that board (AI0 and other) and you are wondering how you can do that? Or I don't understand your question.
Kind regards,
Ion R.
(2,592 Views)
No, I want to see my PC computer in a project and to have acces to its resources as if it was cRio or PC baser RT Target.
(2,582 Views)
There is no mechanism to do that.
(2,577 Views)
