how to Merge two graphs in one?how i can send it to excel sheet?
i used build array but it shows just one graph
see the attachment >>
(3,653 Views)
Technically it is a chart and not a graph.  A chart maintains history allowing you to send data a point at a time.  A graph does not maintain a history.
Use a bundle cluster function to combine the two data points then send to the chart.
Turn on context Help and hover over the terminal for the chart in the block diagram.  It will describe how you have to build the data together for different chart scenarios.  Same situation if you were working with other types of charts or graphs.
(3,647 Views)
How do you want to send the data in the form of picture of graph or chart or the numeric data to excel.
for numeric data you can send it by spreadsheet vi or activex.
There are examples  available, try to search the forums, " Excel Board ".
Regards
(3,636 Views)
