how to Calculate Heart Rate from the Serial data
I want to Calculate Heart Rate from the Data which is ECG coming serially through COM Port.
What could be the technique?
I suppose that i have to use the tick counter and count the time between two pulses and than give the rate.
Could there be anyother good technique?
Message 1 of 10
(4,017 Views)
you could perform a fourier transform to the waveform and evaluate the frequency components.
Cheers
Edgar
Message 2 of 10
(4,015 Views)
Agree with Edgar. The Heart Rate monitor would have coninous, somewhat periodic signals (based on teh activity of teh cocerned indivdual) and the FFT would be the best way forward.
Message 3 of 10
(4,008 Views)
This all depends on the data you are getting from your ECG. If you are receivng the output from the ECG system, then you need to perform post-processing of the data to determine frequency. If you are receiving unsolicited packets at each detected heartbeat then you need to be recording the timings upon arrival and determining frequency from these timings. Can you elaborate a little?
Thoric (CLA, CLED, CTD and LabVIEW Champion)
Message 4 of 10
(4,006 Views)
Thanks to all.
I am getting serial data in single numeric format which is the representation of a voltage amplitude of the ECG.
Since ECG is a low frequency signal, do you think that using FFT Transform could be a good technique.
Also i have to sample my data too for that.
Regards
Message 5 of 10
(3,989 Views)
Thoric is right in that it depends on exactly what data you are receiving.  You've stated you are receiving a voltage signal.  But, are you receiving a continuous signal (lets say you get over 1000 voltage values per second), or are you receiving voltage values only when the ECG exceeds a certain threshold (1 pulse per heartbeat)?  This will determine whether or not FFT is possible for you.
Message 6 of 10
(3,984 Views)
Sampling is good if you want to really analyse your data. you could then very specifically analyse the individual highs and lows and thereby get a better undertsanding of your signal.
Message 7 of 10
(3,977 Views)
Thanks alot, the signal is continuous and is coming at a buad rate of 115200 at the serial port.
Message 8 of 10
(3,950 Views)
I wanted to ask that if i note the time in which the peak is coming using the tick count vi, should i then require sampling of my data?
Message 9 of 10
(3,949 Views)
Yes i would think so. The peak will be one of the analog values which will be sampled. There will also be a point which would be the lowest in term of signal amplitude. Sampling effectively takes points in your data based on your sampling rate, frequency etc.
Message 10 of 10
(3,946 Views)
