how matlab function is work in labview
hi all
i have implenet a function say
function [op]=myimplement(ip) in Matlab
& i have used it in simulink as Matlab function
as i have attached the both matlab file name & also Simulink file
i want to convert the matlab function int Labview
i have tried by using Matlab script node
but its is not working ??
so where iam doing any mistake??
iam also attaching Labview file as well name funct.vi
waiting for any kind replay
thnaks
(2,627 Views)
As it is the Matlab node can't really do anything with that. It would be no different than if you have a .m file. You need to call the function. The Matlab node does not do that automatically (and neither does the Matlab editor). Of course, it's probably simpler to just remove the "function" line and have the last line changed to say
uk=[x_ukp1;x_ykp1;x_zkp1;thetakp1(:)];
instead of
op=[x_ukp1;x_ykp1;x_zkp1;thetakp1(:)];
Note: I believe your input variable should be "ip", not "n", since you calculate "n" in the script.
(2,616 Views)
