how does the elapsed time function work?
Hi, I'm new to labview, and I cannot get the elapsed time function to work.  My very simple test VI is attached, and I simply want it to display to elapsed seconds and switch the boolean when the 10s target is reached, but the timer does not seem to start.  Please have a quick look.  Much thanks.
(3,950 Views)
If you're new to LabVIEW, you should really consider checking out one of the Getting Started tutorials. These will be well worth your time. This page should be a decent starting point for you.
Basically, your LabVIEW programming is doing exactly what you're telling it to do. You are telling computer to do the following things in parallel:
1. Get the elapsed time once.
2. Wait 15 seconds.
What you want to tell the computer to do is probably more like:
1. Do the following until TimeElapsed=True
    a. Check the elapsed time to see if it's more than 10 seconds.
    b. Wait about 100ms before trying again.
This involves using a loop (what is missing from your program). So take a look at some of the Getting Started tutorials, which walk you through creating a basic first program. From there, you'll be better equipped to write your program and to understand the answers to the questions you can post to this forum. Hope this helps!
Jarrod S.
(3,945 Views)
Hello Tsantos,
Just a quickie I put togther here using the State Machine Template.
Patrick Allen: FunctionalityUnlimited.ca
(3,920 Views)
