how do you get bookmarks from a word template
I am trying to write a word report using the standard report generating .vis.  Is there a way to retrieve the bookmark names from a word report template. The MS Office Report express vi does this when you specify a custom template.  However I have way more than 17 bookmarks so I plan to write this report using the standard .vis and need the bookmark names.  I would prefer not to have to have a list that i generated but rather have labview grab all the bookmark identifiers.  How does the express vi do this?  I can't seem to figure it out.  thanks in advance
(3,743 Views)
Here's something you can try:
You can find out how the Express VI works by right-clicking on it and selecting Open Front Panel. This opens the Express VI as a sub vi. Then you can view the block diagram. I would suggest you run this in Highlight Execution mode. This should give you more clues on how to get the bookmark names.
Cheers,
Emilie
(3,688 Views)
I need to do the same thing and have opened the front panel of the ms office report.vi but can not see where it is retrieving the bookmarks. Any suggestions?
(3,643 Views)
I found the vi I needed in the wordsub.llbSmiley Wink
(3,613 Views)
