how do u modify polar plots
I would like to modify/control as many features on a polar plot as possible. I am aware of the property node feature, but those seem to be limited in what can be modified. I would like to have control over plot line thickness, fill-in solid color under data, and text size. I have seen these things modified before but I can't figure it out myself. Has anyone had this same issue?
Thanks!
(2,572 Views)
Accepted by topic author robin533
robin533,
It sounds like with as much customization as you want, you might have to dig deep in the code. I would suggest trying to get into the low level code of the Polar Plot VI and seeing if you can modify what it is you're looking for. You can access some pen controls and color options this way.
Cheers!
KyleP
(2,549 Views)
